*pressuresonentity
Creates a pressure load on a surface or an element.
*pressuresonentity entity_type mark_id nodes_mark_id x y z magnitude breakangle onface
HyperMesh Tcl Modify Command
entity_type
Type of entity the load is applied on. (e.g. surfs or elems)
mark_id
The ID of the mark of entities on which to apply the pressure.
nodes_mark_id
The ID of the mark containing nodes that lie on the face of one or more elements (solids only).
x
X component of pressure.
y
Y component of pressure.
z
Z component of pressure.
magnitude
The magnitude of the pressure.
breakangle
The break angle of a solid face.
onface
A logical which determines whether pressures are being applied to faces.
To apply a pressure of 4 on surface 11:
*createmark surfaces,1 11
*pressuresonentity surfaces 1 1 0 0 0 4 30 1
   # Handle error
