*markprojectnormallytosurface
Project nodes, elems, points, or lines onto the surface along the surface normal.
*markprojectnormallytosurface entities markmask surfptr
HyperMesh Tcl Modify Command
entities
The type of entity being projected.
markmask
The mark which contains the entities to project.
surfptr
The ID of the surface to which the entities will be projected
To project nodes 22, 23, 24, and 25 to the surface along the normal to the surface 14:
*createmark(nodes,1) 22 23 24 25
*markprojectnormallytosurface(nodes,1,14)
None.
