*filtertable
Filter unique cells of key strings of selected column(s) and generate a new table considering the indices of key strings in key columns.
*filtertable table=<name> keystring=<string1, string2, ... stringN> keycolumns=<column1, column2, ... columnN> valuecolumns=<column1, column2, ... columnN> targettable=<name>
HyperMesh Tcl Modify Command
Unless otherwise noted, all inputs are mandatory. They may be specified in any order.
The key columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
The key strings of the selected columns, separated by commas. These must follow the same sequence as the keycolumns.
table=<name>
The name of the input/source table.
targettable=<name>
The name of the output/target table.
The value columns of the selected table, separated by commas. These must follow the same sequence as the keystrings.
Examples
For a given sourcetable table, filter 2 from layerindex column, 2_3_0 from loadcase column and get elementid and TAU12 columns output to a new table named targTable:
*filtertable table=sourcetable keystring={2,2_3_0} keycolumns={layerindex,loadcase} valuecolumns={elementid,TAU12} targettable=targTable
   # Handle error
Version History
2020
