*linesplitatline
Splits a group of lines at a line.
*linesplitatline mark cut line
HyperMesh Tcl Modify Command
mark
The ID of the mark which contains the lines to be cut.
cut line
The line to which the selected lines should be cut.
To cut lines 14, 15, and 16 to line 12:
*createmark(lines,1) 14 15 16
*linesplitatline(1,12)
*createmark() is required.
None.
