*linemesh_saveparameters
Assigns meshing parameters to line or node list segments for 1D meshing.
*linemesh_saveparameters segment density bias bias_style
HyperMesh Tcl Modify Command
Each call to this command must be paired with a call to *linemesh_preparedata1 or *linemesh_preparenodeslist1.
segment
The ID of the segment within the line or node list selection. This index is 0 based.
density
The element density to use for that segment.
bias
The biasing value of the element length to use along the given segment.
bias_style
The style of biasing to use. Valid values are:
0 - linear
1 - exponential
2 - bell curve
To mesh lines 15 and 18 with a 30 degree break angle, with 3 elements in the first segment, and 2 elements in the second segment, creating rigid elements with no property:
*createmark lines 1 15 18
*linemesh_preparedata1 lines 1 30 5
*linemesh_saveparameters 0 3 0 0
*linemesh_saveparameters 1 2 0 0
*linemesh_savedata1 1 5 0 0
None.
