*hf_ResetDFRibs
Reset the ribs attribute.
*hf_ResetDFRibs int_flag
HyperMesh Tcl Modify Command
This command resets the rib attribute. All the ribs that you modify, dragging the latitude lines, are checked with two attribute:
  • fixed
  • drag
int_flag
Integer dummy value. Should always be set to 0.
To reset all the rib attributes:
*hf_ResetDFRibs 0
   # Handle error
