*CE_ConnectorAreaMeshWithDetails
Meshes area connectors and updates the width and offset stored on the connector.
*CE_ConnectorAreaMeshWithDetails mark_id element_size element_type element_type2 link_opposite_edges size_control skew_control edge_mesh_algorithm min_size max_size chordal_deviation max_angle area_width area_offset
HyperMesh Tcl Modify Command
mark_id
The ID of the mark of area connectors. Valid values are 1 and 2.
element_size
The element size.
element_type
The element type for mapped meshing algorithms:
0 - Trias
1 - Quads
2 - Mixed
3 - R-trias
element_type2
The element type for free meshing algorithms:
0 - Trias
1 - Quads
2 - Mixed
3 - R-trias
link_opposite_edges
0 - Do not link
1 - Link
size_control
0 - Off
1 - On
skew_control
0 - Off
1 - On
edge_mesh_algorithm
0 - Standard
1 - Chordal deviation
min_size
The minimum element size when edge_mesh_algorithm is 1.
max_size
The maximum element size when edge_mesh_algorithm is 1.
chordal_deviation
The chordal deviation value when edge_mesh_algorithm is 1.
max_angle
The maximum angle between edges when edge_mesh_algorithm is 1.
area_width
The new width value.
area_offset
The new offset value.
Examples
To update area connector 10 with width 2.0 and mesh it with a default edge size of 1.0:
*createmark connectors 1 10
* CE_ConnectorAreaMeshWithDetails 1 1.0 1 1 1 0 0 0 0 0 0 0 2.0 0.0
   # Handle error
Version History
2021
