*includesuppressoutput
Sets the export/do not export state of all supported entities contained within the specified include file.
*includesuppressoutput include_id include_shortname state
HyperMesh Tcl Modify Command
This command sets the export/do not export state of all supported entities contained within the include file (but not the include file itself) with include_id and include_shortname. Only one of these two options need to be specified, however include_id will take precedence if specified. Double quotes "" must be used for an argument that is not specified.
The state argument indicates the export/do not export status for the supported entities contained in the include. A state of 0 indicates to set the entities to "export". A state of 1 indicates to set the entities to "do not export".
Include files do not have an export/do not export state that is controlled by this command. Instead use the command *updateincludedata2.
To set all supported entities contained within include file ID 5 to "export":
*includesuppressoutput 5 "" 0
To set all supported entities contained within include file shortname include.txt to "do not export":
*includesuppressoutput "" include.txt 1
   # Handle error
Version History
9.0
