*solidmap_set_source_size
Sets the source 2D mesh size for the next call to *solidmap_end.
*solidmap_set_source_size size
HyperMesh Tcl Modify Command
Sets the source 2D mesh size for the next call to *solidmap_end. This allows setting the along size (density) and the source size independently. The command applies only the next call to *solidmap_end. If this command is not called before *solidmap_end, the value of the source size to set to the same as the along size.
size
The solid map source size.
Examples
To set the solid map source size to 1.5:
*solidmap_set_source_size 1.5
   # Handle error
Version History
2020
