*linearsolids
Creates solid elements between two groups of plate elements.
*linearsolids mark1 mark2 align1 align2 align3 align4 align5 align6 number biasstyle biasing
HyperMesh Tcl Modify Command
mark1
The ID of the mark containing the first group of plate elements.
mark2
The ID of the mark containing the second group of plate elements.
align1
The ID of the node to be used as an alignment node for the first group of elements.
align2
align3
align4
The ID of the node to be used as an alignment node for the second group of elements.
align5
align6
number
The number of solid elements to be created between the two groups of plate elements.
biasstyle
The type of biasing to use.
biasing
The biasing factor for the mesh.
To create 8 solids between plates 10, 11, 12, 13 and 20, 21, 22, 23, with alignment node 1 being node 5 and alignment node 2 being node 6:
*createmark(element,1) 10 11 12 13
*createmark(element,2) 20 21 22 23
*linearsolids(1,2,5,0,0,6,0,0,8)
*createmark() is required and the marks used must contain plate elements.
None.
