*surfacemode
Sets the mode for automesh surface and shell mesh generation.
*surfacemode mode
HyperMesh Tcl Modify Command
mode
1 - Mesh, keep surface
2 - Mesh, delete surface
3 - Mesh without surface
4 - Surface only
To set the mode to mesh, delete surf:
*surfacemode 2
   # Handle error
