*freeshapedesvarcreatewithmethod
Creates a free shape design variable.
*freeshapedesvarcreatewithmethod entity_type mark_id name method
HyperMesh Tcl Modify Command
entity_type
The type of entity used in creating the design variable. Valid values are nodes, elements, sets (nodal only), or properties.
mark_id
The ID of the mark of entities used to create the design variable. Valid values are 1 and 2.
name
The name of the design variable.
method
0 - CLASSIC
1 - GRID
2 - BLANK
To create a free shape design variable fsh1 comprised of nodes, with method BLANK:
*createmark nodes 1 2110 3292
*freeshapedesvarcreatewithmethod nodes 1 "fsh1" 2
To create a free shape design variable fsh2 comprised of a node set, with method CLASSIC:
*createmark sets 1 "set1"
*freeshapedesvarcreatewithmethod sets 1 "fsh2" 0
   # Handle error
Version History
2019.1
