*unrealizeengineeringentity
Unrealize an engineering entity.
*unrealizeengineeringentity entity_type entity_id unrealize_mode
HyperMesh Tcl Modify Command
entity_type
The type of engineering entity to unrealize.
entity_id
The ID of the engineering entity to unrealize.
unrealize_mode
0 - Delete entities from realization. Only current solver/profile is affected.
1 - Maintain entities from realization. Only current solver/profile is affected.
10 - Delete entities from realization. All entities including other solvers/profiles are affected.
11 - Maintain entities from realization. All entities including other solvers/profiles are affected.
Unrealize mass with ID 10:
*unrealizeengineeringentity masses 10 0
   # Handle error
Version History
2017.2
