*surfmark_trim_by_surfmark
Trims surfaces along the intersection(s) with other surfaces.
*surfmark_trim_by_surfmark mark_id1 mark_id2 mode
HyperMesh Tcl Modify Command
mark_id1
The ID of the mark containing the selection of surfaces to be trimmed. Valid values are 1 and 2.
mark_id2
The ID of the mark containing the selection of surfaces to use as the trim tool. Valid values are 1 and 2.
mode
  • 0 - Surfaces on mark_id1 are trimmed by the surfaces on mark_id2
  • 1 - Surfaces on both marks trim each other
  • 2 - Surfaces on mark_id1 are trimmed by virtually extending surfaces of mark_id2
To trim all surfaces on mark 1 by those on mark 2:
*createmark surfs 1 1-100
*createmark surfs 2 101-200
*surfmark_trim_by_surfmark 1 2 0
   # Handle error
