*setcuttingplanethicknesson
Turns the specified cutting plane thickness on/off.
*setcuttingplanethicknesson axis state
HyperMesh Tcl Modify Command
axis
The axis that is normal to the plane. Valid values are:
  • 0 - the plane with x-axis as its normal
  • 1 - the plane with y-axis as its normal
  • 2 - the plane with z-axis as its normal
state
Specifies the thickness state for the specified cutting plane. Valid values are:
  • 0 - off
  • 1 - on
To turn off the thickness for cutting plane with y-axis as its normal:
*setcuttingplanethicknesson 1 0
   # Handle error
