*elementqualityshutdown
Closes down a session of the interactive element cleanup tool.
*elementqualityshutdown dontsaveflag
HyperMesh Tcl Modify Command
dontsaveflag
A nonzero value tells the system that it should not transfer your changes from within the element cleanup tool to the permanent database.
*createmark(elements,1) 10 11 12 13 14 15 16
*elementqualitysetup(1)
<<various *elementquality commands>>
*elementqualityshutdown(0)
