*tetmesh_set_input
*tetmesh_set_input entity_type1 mark_id1 mode1 entity_type2 mark_id2 mode2
HyperMesh Tcl Modify Command
Supplies additional input to *tetmesh.
For the special case that both inputs are inactive, this command clears selections from all previous calls to *tetmesh_set_input and *tetmesh. This is normally not necessary since such cleanup is normally done at the end of each call to *tetmesh.
entity_type1
The first entity type. Valid values are nodes, elems, comps, surfs and solids.
mark_id1
The ID of the mark containing the first entities. Valid values are 0 (inactive input), 1 and 2.
mode1
  • -1 - Ignored (inactive input)
  • 0 - Float without boundary layer
  • 1 - Fixed without boundary layer
  • 2 - Float with boundary layer
  • 3 - Fixed with boundary layer
  • 4 - Size control boxes
  • 5 - Anchor nodes
  • 6 - 3D re-mesh
  • 7 - 3D re-mesh with free boundary swappable-float.
  • 8 - 3D re-mesh with free boundary remeshable-float.
  • 9 - Remeshable-float without BL
  • 10 - Remeshable-float with BL,
  • 11 - Elem input for fluid volume selection. Either touched (or normal pointed into) are fluid volumes.
entity_type2
The second entity type. Valid values are nodes, elems, comps, surfs and solids.
mark_id2
The ID of the mark containing the second entities. Valid values are 0 (inactive input), 1 and 2.
mode2
  • 5 - Anchor nodes
  • 6 - 3D re-mesh
*createstringarray 1 "tet: 579 1.2 2 0 0.8 0 0"
*createmark comps 1 "^elem_size_ctrl_0.1" "^elem_size_ctrl_0.5"
*tetmesh_set_input comps 1 4 elems 0 -1
*createmark comps 2 "float_shells"
*createmark comps 1 "fixed_shells"
*tetmesh comps 2 0 comps 1 1 1 1
   # Handle error
Version History
11.0
