*midsurface_offset_by_targets_11
Offsets a surface according to the targets that are attached to its vertices and edges.
*midsurface_offset_by_targets_11 surface mode
HyperMesh Tcl Modify Command
surface
The ID of the surface to offset.
mode
The mode for the selected surfaces. Valid values are:
1 - Preserves the planarity of the surfaces that were planar before the offset
Any other value - A planar surface might become curved if the targets set to offset the surface are not in one plane.
To offset the mid-surface from a surface with ID 109:
*midsurface_offset_by_targets_11 109 1
None.
Version History
11.0
