*compositeanalysis
Analyzes composite materials, plies, sequences or laminates.
*compositeanalysis entity_type <select_type>=<selection> result=<value> output=<value>
HyperMesh Tcl Modify Command
entity_type
The type of entity to modify.
The entity or entities that are to be analyzed. There are several ways to provide the entities to be modified. Only one option can be used at a time:
id=<id>
The ID of the single entity to modify.
name=<name>
The name of the single entity to modify.
mark=<mark_id>
The ID of the mark containing the entities to modify.
result=<value>
The type of result. Valid values are:
23d-behavior - For material or ply analysis
25d-behavior - For sequence or laminate analysis
output=<value>
The file name of the output .csv file.
Examples
To analyze material with ID 1:
*compositeanalysis mats id=1 result=23d-behavior output=C:/temp/result.csv
   # Handle error
Version History
2020.1
