*clearmark
Clear all entity IDs of the passed entity type from the specified mark.
*clearmark entity_type mark_id ?"by model" <model_name>?
HyperMesh Tcl Modify Command
This command clears all entity IDs of the passed entity type from the specified mark.
entity_type
The type of entity mark to clear.
mark_id
The mark ID. Valid values are 1 and 2.
The optional model to clear the mark from. If not specified, the current model is used.
Examples
To clear the components on mark 2 before creating a new mark:
*clearmark comps 2
*createmark comps 2 all
To clear the components on mark 2 for model model-2 before creating a new mark:
*clearmark comps 2 "by model" model-2
*createmark comps 2 "by model" model-2 all
   # Handle error
Version History
2020 - Added new option "by model".
