*nodemodify
Modifies the location of a node in space.
*nodemodify nodeid x y z
HyperMesh Tcl Modify Command
nodeid
The ID of the node to be modified.
x
The new x coordinate of the node.
y
The new y coordinate of the node.
z
The new z coordinate of the node.
To modify the location of node 1 to be x = 10.0, y = 20.0, z = 30.0:
*nodemodify(1,10.0,20.0,30.0)
None.
