*masselement
Creates a mass element.
*masselement mark mass property name system id
HyperMesh Tcl Modify Command
mark
The mark ID which contains nodes which should have mass elements created on them.
mass
The mass of the mass elements.
property name
The name of the property to which the elements should point.
system id
The ID of the system in which the mass elements are built.
None.
