*modelcheck_createchecks
Loads a model check config file and creates check and correction entities.
*modelcheck_createchecks filename ?add?
HyperMesh Tcl Modify Command
filename
The full path and file name of the config file to load.
add
0 - Only the checks in the new config file will be loaded (default)
1 - The config file is appended onto the existing checks
Examples
To load the config file C:/temp/my_checks.xml:
*modelcheck_createchecks "C:/temp/my_checks.xml"
To append the config file C:/temp/my_checks.xml:
*modelcheck_createchecks "C:/temp/my_checks.xml" 1
   # Handle error
Version History
2019
