hm_getmodelcheckconcernentityidresultentityid
Finds the list of untied nodes after a Model Checker run.
hm_getmodelcheckconcernentityidresultentityid display_name contact_id
HyperMesh Tcl Query Command
Finds the concerned non projecting untied nodes for a given contact group/interface. Untied node IDs are placed on mark 2.
display_name
The display name of the check to query. Currently supported values are:
  • ? "Un-Tied nodes in Contact Tied" for LS-DYNA
  • ? "Un-Tied nodes in interface type2" for Radioss
contact_id
ID of the contact for which untied nodes are to be found. This must be one of the contact IDs listed in the Model Checker browser after a Model Checker run.
Examples
To find untied nodes for contact with ID 123:
For LS-DYNA:
hm_getmodelcheckconcernentityidresultentityid "Un-Tied nodes in Contact Tied" 123
For Radioss:
hm_getmodelcheckconcernentityidresultentityid "Un-Tied nodes in interface type2" 123
   # Handle error
Version History
14.0
