hm_attributelist
Returns a list of all attribute IDs or names assigned to a specific entity for the current template.
hm_attributelist entity_type entity_name_or_id value ?search_type?
HyperMesh Tcl Query Command
entity_type
The type of entity to query.
entity_name_or_id
The name or ID of the entity.
value
The type of list to return. Valid values are:
id - the attribute IDs
name - the attribute names
search_type
By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
-byname - Search only by name.
-byid - Search only by ID.
Examples
To list the attribute IDs for the current template assigned to mat ID 6:
hm_attributelist mats 6 id
To list the attribute names for the current template assigned to mat name 6:
hm_attributelist mats 6 name -byname
   # Handle error
Version History
10-SA1-110
