hm_getadjsurfacesfromsurface
Returns the surfaces adjacent to the specified surface.
hm_getadjsurfacesfromsurface surface_id
HyperMesh Tcl Query Command
surface_id
The ID of the surface to query.
To get the adjacent surfaces for surface 100:
hm_getadjsurfacesfromsurface 100
   # Handle error
