hm_tabledifference
Finds the difference of two HyperMesh tables of the same entity type (subtracts the contents of the second table from the first table) and places the result in the first table.
hm_tabledifference table1 table2
HyperMesh Tcl Query Command
table1
First table.
table2
Second table.
TCL_OK(0) if successful. TCL_ERROR(1) otherwise
This command can be used to find entities unique for a table:
# Creating 2 tables
*createmark comp 1 1 2
hm_marktotable comp 1 t12
*createmark comp 1 2
hm_marktotable comp 1 t2
hm_tabledifference t12 t2;
# T12 contains only comp 1 now
None.
