hm_getbatchparams
Query the values of global mesh parameters.
hm_getbatchparams param1 ?param2? ?param3? ... ?paramN?
HyperMesh Tcl Query Command
- param
- The name of the parameter to query. Valid values can be found in *batchparams_update.
Examples
To query the 3rd row of the first coordinate hole table:
hm_getbatchparams surface_holes_table = {table_id = 0 row_id = 2}
To query the entire default 2D holes table:
hm_getbatchparams surface_holes_table = {table_id = -1}
To query the 2nd row of the fillet table:
hm_getbatchparams surface_fillets_table = {row_id = 1}
To query the element size and element type:
hm_getbatchparams element_size element_type
# Handle error
Version History
2021
