hm_tablelookup
Search a table for an entity ID. The constant 1 is returned if the ID is found. Otherwise, 0 is returned.
hm_tablelookup tableName id
HyperMesh Tcl Query Command
tableName
The name of the table.
id
The ID to search for.
When the current model is deleted, or a new model is loaded, all tables are cleared. See hm_marktotable for a sample use of hm_tablelookup.
None.
