hm_elemlist
Get a list of element IDs or types for the passed component.
hm_elemlist listType compName
HyperMesh Tcl Query Command
listType
Type of list to generate (ID or type).
compName
The name of the component containing the elements.
To generate a list of elements IDs of type elemType for a named component.
set elemIds   [ hm_elemlist id $compName ];
set elemTypes [ hm_elemlist type $compName ];
set numIds [ llength $elemIds ];
set elemList {};
for { set i 0 } { $i < $numIds } { incr i } {
set curType [ lindex $elemTypes $i ];
if { $curType == $elemType } {
lappend elemList [ lindex $elemIds $i ];
return $elemList;
This command returns an empty list, if the component is empty or if the component does not exist.
None.
