hm_modelcheckneedscorrection
Determines if an auto correction is required for a given check.
hm_modelcheckneedscorrection ?check_display_name?
HyperMesh Tcl Query Command
Returns 1 if an auto correction is required for a given check. Checks with auto correction should be run and have failed entities before running this command.
check_display_name
The GUI display name of the check. This is case sensitive.
If not specified, then all checks in the current profile are considered and if any of them require correction and support auto correction, 1 will be returned.
Examples
To get the correction status for the "Unused materials" check:
hm_modelcheckneedscorrection "Unused Materials"
   # Handle error
Version History
2019
