hm_getareaofsurface
Returns the area of a surface.
hm_getareaofsurface entity_type entity_id
HyperMesh Tcl Query Command
entity_type
The type of entity to query. Only surfaces are valid.
entity_id
The ID of the entity to query.
To get the area for surface 100:
hm_getareaofsurface surfs 100
   # Handle error
