hm_comparegettransformationmatchstate
Returns the state of a specific transformation and match.
hm_comparegettransformationmatchstate transformation_index match_index
HyperWorks Tcl Query Command
Returns the state of a specific transformation and match. This must be preceded by a call to a relevant hm_compareentities* command.
Possible return values are:
0 - Inactive
1 - Active
The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
match_index
The index of the match corresponding to the transformation_index to query, starting with 0. The number of matches can be found using hm_comparegettransformationmatchcount.
To find the state of transformation 0 and match 5 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
set match_state [hm_comparegettransformationmatchstate 0 5]
hm_compareend
   # Handle error
Version History
12.0
