hm_pathmanager
Returns all search paths, and runs a specified procedure for each path.
hm_pathmanager filename procname
HyperMesh Tcl Query Command
Returns all search paths, and runs a specified procedure with each path (including filename) as input.
filename
The name of the file targeted by the procedure. The command searches for this file in the following directories (in the order listed):
  • The paths specified in the environment variable HW_CONFIG_PATH
  • The user's home directory
  • The current working directory
procname
The Tcl procedure to run. This is run for each returned path. The full path and filename are passed as input to the procedure.
To run the ::showpath Tcl procedure (which displays the file path of a specific file) on all paths for the file called setup.dat:
hm_pathmanager setup.dat ::showpath
   # Handle error
