hm_gethmfileuserprofile
Returns the user profile information saved in the HyperMesh database.
hm_gethmfileuserprofile filename
HyperMesh Tcl Query Command
Returns the user profile information saved in the specified HyperMesh database. The string is comprised of 3 parts, application, profile and subprofile. For example: HyperMesh RadiossBlock Block140
filename
The full path and filename of the database file. Paths with spaces must be enclosed in quotes.
To get the user profile for C:\temp\test.hm:
hm_gethmfileuserprofile  C:/temp/test.hm
   # Handle error
Version History
14.0
