Deprecated Tcl Query Commands
The list of deprecated Tcl query commands, and the new commands to use.
Deprecated Commands New Commands to Use
hm_attributearray2dcols hm_getvalue
hm_attributearray2drows hm_getvalue
hm_attributearray2dvalue hm_getvalue
hm_attributearraylength hm_getvalue
hm_attributearrayvalue hm_getvalue
hm_attributeentityid hm_getvalue
hm_attributeindexarray2dcols hm_getvalue
hm_attributeindexarray2drows hm_getvalue
hm_attributeindexarray2dvalue hm_getvalue
hm_attributeindexarraylength hm_getvalue
hm_attributeindexarrayvalue hm_getvalue
hm_attributeindexentityid hm_getvalue
hm_attributeindexmax hm_getvalue
hm_attributeindexvalue hm_getvalue
hm_attributemax hm_getvalue
hm_attributevalue hm_getvalue
hm_bag_getentitylistall hm_getvalue
hm_bag_getentitylistmax hm_getvalue
hm_baglist hm_entitylist
hm_buffercommandfile *setoption/hm_getoption buffer_command_file
hm_ce_getcollector hm_ce_detailget
hm_ce_removelinkentity *CE_MarkRemoveLink
hm_ce_size *CE_GlobalSetDouble
hm_commandfilestate *setoption/hm_getoption command_file_state
hm_complist hm_entitylist
hm_curve_getnumberofpoints hm_getvalue
hm_curve_getpointcords hm_getvalue
hm_dlinkgetdesvarcoeffs hm_getvalue
hm_dvprelgetdesvarcoeffs hm_getvalue
hm_dvprelgetdesvars hm_getvalue
hm_elempropertyget hm_getvalue
hm_entity_setproperty *setvalue
hm_entityinfo bbox hm_getboundingbox
hm_evaluatemathexpr Tcl math expressions
hm_fe_setdiameter *CE_DetailSetDouble or *CE_DetailSetDoubleByMark
hm_fe_setpropscript *CE_DetailSetDouble or *CE_DetailSetDoubleByMark
hm_feoutputselect *feoutput_select
hm_getcardimagename hm_getvalue
hm_getcardimagenamemark hm_getvalue
hm_getcardimagetype hm_getvalue
hm_getcardimagetypemark hm_getvalue
hm_getcentroidofsolids hm_getcentroid
hm_getcleanuptol hm_getoption cleanup_tolerance
hm_getcompthickness hm_getthickness
hm_getcontrolcardattribute hm_getvalue
hm_getcoordinates hm_getvalue
hm_getdeleteelementsmode hm_getoption delete_elements_mode
hm_getdisplaycolor hm_getoption background_colors
hm_getelementsize hm_getoption element_size
hm_getentityarray hm_getvalue
hm_getentityvalue hm_getvalue
hm_getgeometrybox hm_getboundingbox
hm_getincludechildren hm_getvalue
hm_getincludeid hm_getvalue
hm_getincludename hm_getvalue
hm_getloadoption hm_getoption equation_handle
hm_getoption load_handle
hm_getoption load_label
hm_getoption load_size_magnitude
hm_getoption load_size_type
hm_getoption load_size_uniform
hm_getoption load_solver_label
hm_getmarkarray hm_getvalue
hm_getmarkvalue hm_getvalue
hm_getmeshlinecolor hm_getoption mesh_line_color
hm_getnodetol hm_getoption node_tolerance
hm_getoption displayscale hm_getoption display_scale
hm_getoption fixed_points hm_getoption fixed_point_handle
hm_getoption geometry_handle hm_getoption line_handle
hm_getoption geomstitching hm_getoption geom_stitching
hm_getoption loadvisualvector hm_getoption load_visual_vector
hm_getoption perspective_value hm_getoption perspective_view
hm_getoption outputtimeinfo hm_getoption feoutput_time_info
hm_getoption shrink_value hm_getoption shrink_factor
hm_getoption shrink_mode
hm_getoption tagdisplay hm_getoption tag_display
hm_getoption tagtextdisplaymode hm_getoption tag_text_display_mode
hm_getoption view_acceleration hm_getoption graphics_simplification_mode
hm_getsystemoption hm_getoption system_size_uniform
hm_gettablecelldata hm_getvalue
hm_gettablecolumndata hm_getvalue
hm_gettablecolumnlabel hm_getvalue
hm_gettablecolumnsize hm_getvalue
hm_gettablecolumntype hm_getvalue
hm_gettablerowdata hm_getvalue
hm_gettopologyoption hm_getoption solid_transparency
hm_getoption topology_edge_display_mode
hm_getoption topology_solid_display_mode
hm_getvectoroption hm_getoption vector_auto_scale
hm_getoption vector_handle
hm_getoption vector_label
hm_getoption vector_size_magnitude
hm_getoption vector_size_type
hm_getoption vector_size_uniform
hm_grouplist hm_entitylist
hm_info automeshcolormode hm_getoption auto_mesh_color_mode
hm_info blockredraw hm_getoption block_redraw
hm_info clipboundaryelements hm_getoption clip_boundary_elements
hm_info displayimporterrors hm_getoption display_import_errors
hm_info duplicateids hm_getoption duplicate_ids
hm_info elementcolormode hm_getoption element_color_mode
hm_info elementinternaledgesmode hm_getoption element_internal_edges_mode
hm_info elems_cleanup hm_getcurrentmenu
hm_info entityhighlighting hm_getoption entity_highlighting
hm_info fieldofview hm_getoption perspective_fov
hm_info geomrefinelevel hm_getoption geom_refine_level
hm_info geomstitching hm_getoption geom_stitching
hm_info lodthreshold hm_getoption lod_threshold
hm_info meshtransparency hm_getoption mesh_transparency
hm_info mixedpropertywarning hm_getoption mixed_property_warning
hm_info perspectiveview hm_getoption perspective_view
hm_info picktolerance hm_getoption pick_tolerance
hm_info plythicknessfactor hm_getoption ply_thickness_factor
hm_info retainloads hm_getoption retain_loads
hm_info rotationangle hm_getoption rotation_angle
hm_info rotationcentermode hm_getoption rotation_center_mode
hm_info rotationcenteroffscreen hm_getoption rotation_center_off_screen
hm_info scalecolor hm_getoption scale_color
hm_info scaleheight hm_getoption scale_height
hm_info scaleposition hm_getoption scale_position
hm_info scalewidth hm_getoption scale_width
hm_info showcompositelayers hm_getoption show_composite_layers
hm_info showglobalaxes hm_getoption show_global_axes
hm_info showscale hm_getoption show_scale
hm_info shrinkoptionvalue hm_getoption shrink_factor
hm_info shrinkvalue hm_getoption shrink_mode
hm_info stereodisplay hm_getoption stereo_display
hm_info surfaceuvlines hm_getoption surface_uv_lines
hm_info topologydisplaymode hm_getoption topology_display_mode
hm_info transparentwithmeshlines hm_getoption transparent_with_mesh_lines
hm_info zoomfactor hm_getoption zoom_factor
hm_materiallist hm_entitylist
hm_morph_getdomainelems hm_getvalue
hm_morph_getdomainhandles hm_getvalue
hm_morph_getdomainnodes hm_getvalue
hm_morph_domaintypecount hm_morph_getinfo
hm_morph_getcountercurrent hm_morph_getinfo
hm_morph_getcountermaximum hm_morph_getinfo
hm_morph_getinfo parameter domainicons hm_getoption domain_handle
hm_morph_getparameter hm_morph_getinfo
hm_nodelist hm_getvalue
hm_nodergb
hm_nodevalue hm_getvalue
hm_parentcomplist hm_getvalue
hm_propertylist hm_entitylist
hm_setlist hm_entitylist
