hm_ce_fedata
Returns the weld config or the tolerance set to realize a connector.
hm_ce_fedata ce_id function
HyperMesh Tcl Query Command
ce_id
The ID of the connector.
function
One of three possible strings:
configval - returns the configuration number
configname - returns the configuration name
tolerance - returns the realization tolerance
To get the current weld config set for connector with ID 1:
set ce_id 1;
set config [ hm_ce_fedata $ce_id "configval" ];
Currently only configval and tolerance are supported for the connector.
None.
