hm_ce_numlinkentities
Returns the number of link entities for the connector.
hm_ce_numlinkentities id
HyperMesh Tcl Query Command
id
The ID of the connector to query.
To get link information for connector ID 1 for all links:
set ce_id 1
set num_ents [hm_ce_numlinkentities $ce_id]
for {set count 0} {$count <= $num_ents} {incr count} {
  foreach {type info state rule} [hm_ce_getlinkinfo $ce_id $count] {
    lappend linkArray($type) $info
   # Handle error
