hm_getfacesfromsurface
Gets faces contained in the surface whose ID is supplied as the argument.
hm_getfacesfromsurface surface_id
HyperMesh Tcl Query Command
surface_id
ID of the surface.
The function returns a list containing IDs of the faces from which the surface is composed.
To get faces that compose the surface with ID 2:
hm_getfacesfromsurface 2
None.
