hm_getfilletfaces
Returns the faces containing fillets with a radius inside a range.
hm_getfilletfaces radius_min radius_max
HyperMesh Tcl Query Command
radius_min
The minimum radius value.
radius_max
The maximum radius value.
To get the faces with fillets with a radius between 5 and 15:
hm_getfilletfaces 5 15
   # Handle error
