hm_getlockedentities
Queries entity locks.
hm_getlockedentities entity_type dataname
HyperMesh Tcl Query Command
This command returns locked entity IDs across all submodels.
entity_type
The type of entity to query locks for.
data_name
The data name to query locks for. Currently only supported for "id".
To query ID locks for all elements:
hm_getlockedentities elems id
   # Handle error
Version History
12.0.110
