*unlockentities
Removes entity locks.
*unlockentities entity_type mark_id dataname
HyperMesh Tcl Modify Command
This command removes entity locks for a selection of entities.
entity_type
The type of entity to lock.
mark_id
The ID of the mark containing the entities to unlock. Valid values are 1 and 2.
dataname
The dataname to unlock. Currently only supported for "id".
To unlock the displayed element IDs:
*createmark elems 1 displayed
*unlockentities elems 1 id
   # Handle error
Version History
12.0.110
