*entitybundleremoveid
Removes a single entity from a data item of a bundle.
*entitybundleremoveid name data_item id
HyperMesh Tcl Modify Command
name
The name of the entity bundle to be modified.
data_item
The data item of the entity bundle to be modified. Note that these indices start with 0.
id
The ID of the entity to remove. Note that the entity type is inferred from the bundle definition.
Examples
To remove entity ID 17 as the first data item of the bundle "compbundle":
*entitybundleremoveid "compbundle" 0 17
   # Handle error
Version History
14.0.130
