*PenetrationCheckSummary
Generates a summary log file for last run penetration check.
*PenetrationCheckSummary filename sort_intersections sort_penetrations
HyperMesh Tcl Modify Command
Command is used to generate a summary log file for last run penetration check. This file contains a flat list of intersected and penetrated components, followed by more detailed lists of each component-component pair data. If the last check’s input was specified by groups, then the above data is organized by groups, as well.
filename
The name of the file, including its full path, to which the summary is written. The file is appended to if it already exists.
sort_intersections
A flag that indicates how to sort intersection data. Valid values are:
  • 0 - No sorting
  • 1 - Ascending component ID
  • -1 - Descending component ID
  • 2 - Ascending element count
  • -2 - Descending element count
  • 3 - Ascending number of interfered components
  • -3 - Descending number of interfered components
sort_penetrations
A flag that indicates how to sort penetration data. Valid values are:
  • 0 - No sorting
  • 4 - Ascending maximum penetration depth
  • -4 - Descending maximum penetration depth
Output results of the last penetration check (run using the command *checkpenetration) to the file C:\results\check.txt, with intersections sorted by ascending component ID and penetrations by descending maximum penetration depth:
*PenetrationCheckSummary "C:/results/check.txt" 1 -4
   # Handle error
Version History
10.0
