*panelcreation
Creates a panel entity.
*panelcreation elemMark=<value> name=<value> findPanel=<value>
HyperMesh Tcl Modify Command
elemMark=<value>
The ID of the input elements. Valid values are 1 and 2.
name=<value>
The name of the panel entity.
findPanel=<value>
0 - DIrectly create the panel entity using the input elements
1 - Find a panel consisting of these elements
Examples
Create a panel named panel1 from elements 1-10:
*createmark elems 1-10
*panelcreation 1 panel1 0
Find panel entities from elements 1-10:
*panelcreation 1 panel1 1
   # Handle error
Version History
2020
