*splitSurfaceRegions
Splits regions based on the connectivity of the contained surfaces.
*splitSurfaceRegions mark=<value> split_mode=<value>
HyperMesh Tcl Modify Command
The surfaces contained in the input regions are grouped, the orignal regions are split based on the groupings, new regions are created for each group, and the original regions are deleted.
mark=<value>
The ID of the mark of input regions. Valid values are 1 and 2.
split_mode=<value>
ByAttached - Group the surfaces by attached
ByFace - Group the surfaces by face
Examples
To split all regions of surfaces by attached:
*createmark regions 1 all
*splitSurfaceRegions mark=1 split_mode=ByAttached
   # Handle error
Version History
2021
