*settransparency
Toggles the shaded surface transparency feature on and off.
*settransparency onoff
HyperMesh Tcl Modify Command
onoff
Determines whether the shaded surface transparency feature is turned on or off.
1 on
0 off
To make the shaded surfaces in these comps on the mark transparent:
*settransparency(1)
*createmark(components,1) "middle"
*transparencymark(1)
None.
