*setlightsource
Set direction of the global light source.
*setlightsource x y z
HyperMesh Tcl Modify Command
x
X axis location, horizontal direction of screen.
y
Y axis location, vertical direction of screen.
z
Z axis location, in/out of screen.
This command may be used in either the hm.cfg file or from a command file.
The default setting is 0.0, 0.0, 1.0 (represents model lighting as you view it).
None.
