*elempatchincraction
Increases the QI patch checker patch size by one element layer.
HyperMesh Tcl Modify Command
This command only functions between an *elempatchstartaction command and an *elempatchstopaction command.
To start the patch checker and move through several patches, changing the patch size, while using quality criteria given from a file:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elempatchstartaction 0 1.0
*elempatchnextaction
*elempatchprevaction
*elempatchdecraction
*elementqualityshutdown 1
   # Handle error
Version History
13.0
