*hf_setdiesymmetry
Sets the symmetry plane for the die module.
*hf_setdiesymmetry normal_x normal_y normal_z origin_x origin_y origin_z shape_flag node_1 node_2
HyperMesh Tcl Modify Command
This command sets the symmetry plane for the die module.
normal_x
x-coordinate of the plane normal.
normal_y
y-coordinate of the plane normal.
normal_z
z-coordinate of the plane normal.
origin_x
x-coordinate of the plane origin.
origin_y
y-coordinate of the plane origin.
origin_z
z-coordinate of the plane origin.
shape_flag
A flag that identifies the following cases:
0 - Half model
1 - Full model that does not contain a symmetry plane
2 - Full model that contains a symmetry plane
3 - Symmetric model for double attached part feature
node_1
First node ID that identifies the portion of the part that is used by the double attached part feature.
node_2
Second node ID that identifies the portion of the part that is used by the double attached part feature.
To set the symmetry plane z=0 for the die module:
*hf_setdiesymmetry 0. 0. 1. 0. 0. 0. 0 0 0
   # Handle error
Version History
11.0
